KitchenAid commercial oven (kdrs483vss04) hidden element (30" side) not getting power / not heating
Brand:
Model Number:kdrs483vss04
Main Symptom: hidden bake element not heating
Bake element has been tested and positive for connectivity / thermal fuse tested positive for continuity
Broiler in large oven works / 18” heating elements work
Test the element to see if it is getting 240 vac to it. If it is but not heating then this will be a faulty heating element and if there is not then the control board will be the issue.
Thank you. That was exactly the issue. Replaced the board and all working great.
