KitchenAid Clean Light blinking 7 times, after reset, motor sounds
Hello All,
I am experiencing the 7 second clean light blinking issue; so far I have downloaded the service manual and searched the archives for similar issues. I have been able to reset the unit, but during the reset process when the unit seems to check all functions, I hear what seems like motor noise. Basically it is a steady low frequency sound that a motor would make if it is not able to turn due to some sort of impedance.
From the threads that I have read, it seems to possibly be either a bad hi limit thermostat or heater element, but the motor noise seems to contradict this diagnosis.
Any help is appreciated.
Aron
[quote=netaron;138295]Hello All,
Aron[/quote]
Aron:
Did you ever figure out the problem with your machine? My KitchenAid is having the exact same problem. Thanks
My Kitchenaid dish washer clean light is blinking 7 times then pause which makes me believe this means something. Did you guys figure out what is broken here? :confused:
