It is not drying the dishes. I have tested the heater coil and it is bad.
Before I order the replacement a thought I would check the active vent
also. I am measuring 1.6K ohms between the lugs on the vent with the wires removed. Is this a normal reading?
FYI, I just called Kitchenaid as my unit is still under the 5 year warranty.
First they told me the heater element was not covered, transfer to supervisor, yes it is.
Then they said it must be diagnosed with a service call at my cost, more than the part costs. Transfer to technical assistance.
Part is bad, will only give heater element, not new control board as recommended. (not good enough)
Finnally we will ship the parts to you at no cost, with the control board and make it 2-3 day at our cost.
Took 30 min, like pulling teeth, but I got the parts for free.
For the uninformed, the original heating element has a problem where the coating comes off and messes the inside of the tub with black gunk. Also why it fails so soon.
The replacement heating element is different, hence the need for the new control board. If your element is not covered for 5 years on your model as mine is you may try to push that the new contol board is covered for 5 years and is part of the replacement part number.
I must say I am very impressed with your negotiating skills
Most people just end up with anger, an upset stomach and a service call bill, when dealing with these companies.
