Kitchen Aid Washer Won't agitate or spin
So the new timer came, I installed it, and nothing changed. I pulled the cabinet off again and checked the lead from the capacitor to the motor connection (that big white connector with lots of wires) and it has continuity.
Just for grins, I pulled the motor out just to make sure that the coupling hadn’t broken a third time and was jamming things up. Nope. Everything is fine.
To recap.
New timer. It ticks and turns.
Lid switch works.
New capacitor.
Pump turns and has nothing stuck in it in it.
Motor turns freely.
More thoughts. I really hate the idea of calling a repair guy out and having him charge me $100 to fix the problem in 30 seconds.
If it wasn’t for the big stack of laundry building up, I’d be enjoying this process.
Thanks for the suggestions so far. I know that troubleshooting is a process of elimination.
So the motor is the final piece of this puzzle I think.
Check the ohms resistance of the start windings and the primary windings of the motor.
unplug the wire harness off the motor and check ohms across the lead with the black wire and the yellow wire. it should read roughly 7.8
then read the ohms across the blue wire and the white wire you should read 1.2 to 1.5
also check for continuity between where the red wire connects and the black wire lead
here you will check to see if the centrifugal switch is connecting thru to the start windings
the start windings may read 5.6
this depends on whether you have a two or three speed motor
if you get a reading of somewhere between 5.4 to 8.2 then the start windings are OK
It’s taken me a while to get back to my washer issue. That silly thing called “work”, especially more of pain since my normal shift is 11 hours. But that is neither here nor there.
Pulled the motor out and have it on my bench. Five wires, left to right: black white with black stripe, blue, yellow and white. There’s another connector dangling off the motor with a molex connector with a wihte/orange and white/purple wires.
Black to yellow: 5.9 ohms
Blue to white: 2.0 ohms
Blue to white/black: 2.0 ohms
White/orange to white/purple: 4.3 ohms
Black to red: open
There’s a little white nubby thing that pokes out of the connector box. If I push that up, I get a reading of of .5 ohms. If I fiddle with it a bit, the reading jumps up and then bounces around.
New development. I unscrewed the connector block from the motor and found that the pivot pin for the the little white nubby thing is broken. A little bit of reading and it looks like the nubby thing is the start switch.
I’m guessing that all I have to replace is the 62850 start switch.
Good job you have found the problem
Replacing it is simple.
Let use know the outcome of your repair.
This is my third try at posting this, it keeps getting rejected.
I ordered a new motor switch but the one that arrived was a broken one in a resealed package. Apparently some douchenozzle returned his broken switch for a refund. The vendor sent me a new on via priority mail. The washing machine now works! Yea!
Now the dryer died. I already took it apart and found that the belt is broken.
Thank you gentlemen for your help, advice, and patience. I now know far more about washers than I ever expected to.
Thanks again.
