Kitchen aid kecc502bbl2 replacement switch diagram part 8203534 has extra wire not on stovetop
Brand:kitchenaid
Model Number:kecc502bnl2
Main Symptom:replacement switch 8203534 diagram has wire identifies not on stovetop
First of all, I am not pulling up this exact model number. plus, which element switch are you trying to replace? It looks like there are several elements and switches. I want to make sure you got the right switch. Let me know.
My apologies it should be KEECC502BBL2. I did see another person installed the same switch. The directions they were given did not mention the additional wire.
Sorry i cannot type this afternoon. It is KECC502BBL2
I still need to know which element you are trying to replace.
Left rear - double burner
So, based on the wiring diagram, black goes to terminal 2, violet 5, yellow 4, yellow/white 3, the double terminal N, should have a red and yellow wire. You should be using 5 terminals on the switch. 3 and 4 go to the inner and outer coils. violet is the wire feeding the ON indicator light. 2 is the L1 feed to the switch. Red is the L2 feed going to the L2 part of the element.
wiringsheet-3190371 (2).pdf (22.9 KB)
If there is a unused terminal, leave it empty. Yopu should only need 5 terminals on the switch.
Thanks - have a great weekend
