Child lock light was on and blinking. Manufacturer instructions did not help. I could take off front panel, unattach ribbon from control board, then reattach. Cycle would begin, but only on light wash. No other buttons could be pushed. Finally ordered a new control board. Installed it and it works…but will only work on normal wash. No other buttons can be activated. Although the washer is working I would like to have the option of selecting other washes. 1. Does a new fuse come with the new control board? If not, could it be the fuse? or 2. Do I need a new front panel? Help!!!
sounds like a bad front pannel. if the button cover is damaged and water or cleaning spray has damaged the pannel you will need to replace the pannel.
the part # is dependant on the pannel color.
There has been no damage to the front panel. No cracks or water damage what so ever. Now what??
