Does the glass stovetop have screws or is it just caulked in place ?
Brand:kitchen-aid
Model Number KGCC566RWW04:
Main Symptom:cracked glass top
Brand:kitchen-aid
The top is installed with a adhesive foam seal no caulk listed
Unfortunately the Fosm Seal has been discontinued by the manufacturer
and is no longer available for purchase.
Whirlpool WP3191933 - [AP6007810] Foam Seal OEM Part
Whirlpool W10661512 - [AP5806024] Cooktop Glass OEM in White
Whirlpool W10661511 - [AP5806023] Cooktop Glass OEM in Black
https://www.appliancepartspros.com/whirlpool-foam-seal-36-wp3191933-ap6007810.html
Thanks. I was removing the top to replace the igniter harness & cracked it. Looks like the prior tech had used caulk on it as well. I ordered a new glass top & hopefully it comes with the adhesive cushion strip. If not, Iām sure there is something close to it.
