KItchen Aid KUDS30IXSS blew the thermal fuse. I passed this off to a power outage. Now the fuse blew again. This particular fuse did not come with the replacement pigtails, so I was wondering where else I should be looking. Apparently, replacing the board is not the answer since I have checked out other posts. Is it possible the drain is clogged, not letting the motor move? Is there somewhere else I can look at the same time?
THX
What is the part number of the thermal fuse you installed?
What is the end of the model number?
[quote=Gene;783504]What is the part number of the thermal fuse you installed?
Gene.[/quote]
Part number is W10402110
Complete model number is KUDS30IXSS4
Make sure the vent is sealing properly and not letting moister and/or steam to the fuse.
Here are the breakdown diagrams and Parts for KitchenAid KUDS30IXSS4 Dishwasher - AppliancePartsPros.com
