My dishwasher won’t turn on. It was working fine, my mother opened the door during the wash cycle to add a dish and all the lights stopped working and it acts like it has no power. The breaker is fine. The repair people say it will cost a minimum of $135 to replace a fuse in it. Where can I find the fuse and replace it myself?
Check the door switches (#2 on the diagram) and the thermal fuse (#22) for continuity before replacing any parts.
Make sure the door switches are properly engaged when the door closed.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KUDI24SEBL4 | AppliancePartsPros.com
Gene,
You Rock!!! Thanks you so much. I will check it out today : )
[QUOTE=Gene;98371]You are welcome. Keep us posted.
Gene.[/QUOTE]
Thank you so much for all your help. It was the fuse in the door that was the problem. We ordered a new fuse and replaced it last night. With only a few scrapes from sharp metal and struggling to get the door to fit back together, all is working great and with no leaks!!! You were such an invaluable part in making our repair successful and you saved us so much money. Thank you again for being so generous with your time and help.
