Kitchen Aid Dishwasher wont cycle
Spray wash won’t come on. Replaced the heating element and after replacing the heating element, the pump that forces the spray wash would not kick on. Replaced capacitor on motor, no luck, Replaced motor, still no luck. Any sugggestions?
If you have replaced the parts that you listed, it sounds like the cycle information is not being sent to the pump motor. In this case the electronic control module located between the switches and the motor may need replacing. The following site will provide additional information that may help you in diagnosing the problem: [COLOR=#810081]http://forum.appliancepartspros.com/dishwasher-repair/28741-kitchen-aide-dishwasher-power-but-wont-cycle-new-post.html[/COLOR]
Hope this helps!
Steve
