Kitchen Aid Dishwasher will not initiate wash cycle
I can select any of the wash cycle (Status Display shows two dashes) but when I touch the Start button all of the lights immediately turn off. When I touch the Start button a second time it will go through the 2 minute wash cancelation mode. I noticed that the High Temp Scrub light will not turn on. I have tried all of cycle choices and non work.
I ordered a new electronic control assembly and just prior to replacing it I tried to start the dishwasher and it started. I switched it to the Normal cycle while still running but it would not switch to the Baked On Cookware cycle and I could not turn on the High Temp Scrub. I let it run through the whole cycle and the dishes seemed to get clean. I could not get it to turn on again after that. The same LED display issues happened again.
I replaced the electronic control assembly and it is still faulting as described above.
Any suggestions on what the problem could be? Is it possible that certain sensors will not allow the dishwasher to turn on? Or do I need to replace the control panel?
Jordan Countdown Pack 20/3From birth to be famous, Kobe Bryant Shoes has been through 23 years. During these years, it brings us so much surprising and moving. Jordan himself also wore air jordan series to create many glory records on playground. And a myth of sneaker history begins its unusual travel.With Flyman’s several retirement, Kobe shoes also went into the trough, but tt has glory imprint which other star’s signature shoes do not have because of its master’s glory. In 2005, Air Jordan series have been through 20 years and Air Jordan 20 which was scalped hot finally was on market at that year. Air Jordan 3 is an era changing of ********. 1987-88 season, Jordan got all important prizes which you can imagine with wearing Air Jordan 3, the first Kobe IV sneaker with Jumpman logo. Regular season MVP, best defensive player, all-star MVP, the second Slam Dunk Champion and so on. Like developing regular of all things, as his closest companion, Air Jordan series has been through trials and hardships with Jordan’s up and down.
