I had the thermal fuse replaced last year and the dishwasher appears to have same problem, the control panel does not light and the unit does not run.
Where can I find a site or buy a manual to show me where the thermal fuse is on this Kitchen Aid dishwasher?
Replacement parts for WHIRLPOOL KUDS24SEBL4 | AppliancePartsPros.com
Here is a tech sheet and a manual
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%209743964.pdf
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/89d39c1d212f21eb85256ab000567fd2/$FILE/4317196.pdf
The fuse is item 22 in Section 2.
Note that it comes with a wiring harness this must be used.
Was it replaced when the fuse was replaced, if not that may be the problem.
Your symptoms can be caused by a number of things so it may not be the fuse. Best to check it with a meter.
Check that the unit is getting power. I have had several units where the wire nut connections have gone bad so even though there is power to the unit it is not getting power.
Also a bad door switch or a switch that is not closing could be the cause.
