I have a Kitchen Aid KUDP02CRBS1 dishwasher. After searching the forums I’m still not clear on which part I should replace. Initially the problem showed up as the Quick Clean, Rinse Only and Heat Dry buttons being the only ones that would light up when pressed and we were unable to get the washer to start. Pressing any buttons other than those three did nothing at all. After reading some of the other posts about bad buttons on these washers I took apart the door panel and checked the ribbon cable. It looked okay so I just pulled it off and re-seated it. I turned the circuit back on for the washer and now the Quick Rinse and Rinse Only buttons still light up but the Heat Dry button blinks 3 times and goes back off. No other buttons work at all so we are still unable to use the washer.
So is this a control panel that needs to be replaced, the overlay, the ribbon cable, some combination of those or something else I’m missing entirely?
Take a look at Section 2.
It could be the console (keypad) Item 1, the ribbon cable item 2, the interconnect board item 5 or the control board item 11.
If you look at the tech sheet you will see that the 3 keys you mentioned first all use P1-6 as a common.
You may want to try the following first.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the various connections between the 4 parts.
Clean the edge connector.
Clean the other connectors. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
If the above does nothing check the ribbon cable and interconnect tracks for continuity using a meter.
If all OK then check the console (keypad) keys with the meter,see the tech sheet.
If the console fails then order that.
If all the above are OK then the control board is the most likely culprit.
Still a bit of a crap shoot but your odds are better if you can actually narrow down the fault.
If you do the above checks and order a part from AppliancePartsPros they will let you return the part if it does not fix your problem.
See their return policy.
Always remove power from the machine otherwise you could blow your meter.
Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
There is a good STICKY at the start of this forum about it’s use. KUDP02.pdf (250.6 KB)
I wasn’t able to find any faults with the meter. Based on other threads it seemed like the control board would be most likely so I ordered it. Got it this afternoon and installed it and it wasn’t the problem. It seems like the ribbon cable and interconnect are pretty basic to put on the meter so I’m more confident that it isn’t either of those. I’ll order the button overlay next and hope that fixes it. Thanks for your help.
