Kitchaide dishwasher is not starting when pressing the start button.
Keypad lights for “Normal” , “High Temp Scrub” and “Cancel” are continuing to
flash non-stop, pressing any other buttons does not clear it. Tried
the diagnostic sequence and does not respond, lights just keep flashing.
I imagine it is the control panel which is likely the cuplrit, does that sound correct, and what would be the part number ? would cleaning the ribbon
be worth a try as well ?
It shows High Temp : Start/Resume and Normal all use connection P1-4.
I would try cleaning the connectors first.
Unplug the unit
Open it up
Clean the edge connector.
If that does nothing check the keys using a meter.
If they are no good replace the control panel.
If they are good replace the control board.
Still a bit of a crap shoot but your odds are better.
thanks for the response, i went through and cleaned the contacts for both ribbon cable and the other connectors to the board (the ones for each of the keys) , i admit things looked a bit dirty on some of them, i threw power back
on and the High heat button was blinking, i tried the diagnostic sequence, and it cleared everything, no blinking lights this time, then hit the Normal wash, and start and things worked fine, dishwasher is running! , now my question is , based on what i saw in the circuit board, there was probably a short in the board caused by a nasty connector, based on the activities i just went through do you think it is almost definitely the board (thats what i think now for sure), just in case this happens again so i know what to swap out.
Odds are you will not have problems in the future though it may get dirty again.
I cannot say what was the cause/result, if cleaning does not fix it down the road then you will have to check the keypad to determine the most likely cause.
