[FONT=Book Antiqua][SIZE=3][COLOR=darkred]Hello. My Kenmore front load washer would stop in between cycles and I would have to restart it. I feel like the door isn’t closing properly and stopping the cycles? Now the washer will not start at all. The light above the start button is blinking and all four buttons to the right are lit up. One of them says that the door is locked but I can open the door. I looked behind the control panel for the tech diagnostic codes to run a test and there was nothing there. How can I run the proper test? Thanks Jen :rolleyes: [/COLOR][/SIZE][/FONT]
The tech notes on these Frigidaire made machines are inside the lower service panel.
It sounds like your door lock assembly has failed so check that out first.
