Kenmore Washer Dryer Combo disassembly 110.88732791 (11088732791, 110 88732791)
When I search for disassembly, I can’t figure out how to get the front of the cabinet off to replace the drain pump. I already bought the drain pump but there are no screws on the bottom of the front of my unit. There are what appear to be 2 plastic clips on the top of the cabinet, one of which is broken, but I can’t figure out how to open it. When the technician looked at it and diagnosed the drain pump (and likely broke one of the clips), he took the top off before the front.
Brand:Kenmore
**Model Number:**110.88732791
Main Symptom:Need to replace drain pump
What happens & when: Drain pump makes bad sound, tech said drain pump needs to be replaced
Parts or tests already tried: Ordered WP3363394 but can’t figure out how to install
