Kenmore wall oven gets up to temp & shuts off, about 50% of the time I use the oven
Brand: Kenmore
Model Number: 79030529802
Main Symptom:
Hi Alberatzi, welcome to the forum!
On your Kenmore 790.30529802, this is a gas wall oven, and the first thing I would suspect with the symptom you described is a weak bake igniter, especially if the oven reaches temperature normally and then fails to come back on after the burner cycles off.
The bake burner is supposed to shut off once the oven reaches temperature. As the oven cools a little, the igniter should glow again and the burner should relight. A weak igniter can work when cold, then become unreliable once it gets hot. That can make the problem seem intermittent, such as only happening about half the time.
Your model uses the flat-style bake igniter 5303935066.
Here’s what I’d check:
  1. Set the oven to Bake 350°F and watch it through a complete heating cycle.
  2. After it reaches temperature and the burner shuts off, wait for the temperature to drop enough that it calls for heat again.
  3. Watch the bake igniter.
    • Igniter glows but the gas burner does not relight: very strong indication the igniter is weak.
    • Igniter does not glow at all: then we need to check voltage from the control and wiring before replacing parts.
  4. If you have a clamp-style amp meter, measure the current through one igniter wire while it is glowing. This style igniter should draw approximately 3.2–3.6 amps. If it is below that range, replace the igniter.
One important distinction: if by “shuts off” you mean the display/control panel actually goes blank, that points us in a different direction—power supply, wiring, or the electronic oven control 318185338 rather than the igniter. That control is also used on this model.
So before ordering anything, let me know what happens when it fails: Does the clock/display stay on, and does the igniter glow when the oven should be reheating? That will narrow this down pretty quickly.
