Kenmore Ultrawash III
My dishwasher for a while took forever to get off the 37 when the minute cycle wash counting down. After a while it would finish. Now when I turn it on, I get a clicking sound, and then nothing. A little while later more clicking and nothing. Then it goes through the cycle and doesn’t wash the dishes and the water is still in the bottom. Once in a while it will wash them fine, then it does nothing again. Thanks for any help.
A Model Number may help others help you, probably why you have not received a reply yet.
I would try disconnecting the unit from power for half an hour or so just to see if it will reset.
Next I would clean/check the keypad connection
RIBBON CABLE CLEANING
Unplug the unit
Open it up
Clean the edge connector.
