Kenmore series 500 brake release problem
A direct drive style washer.
What is -suppose- to happen is the water drains out and the washer pauses and this pause allows the tranny to set up for spinning to occur. The pause is created by the timer.
Pause not there or intermittent pauses is a timer issue.
Pause is good but the tranny is not changing from agitation to spin is a tranny/gearbox issue.
Weak/slow spin is often the clutch. Spinning and stopping may also be a clutch issue.
Not to confuse you further but you may have 1, 2 or 3 issues :frowning:
All the best in your repair.
jeff sr.
