Kenmore model 10651764510 side by side ice maker not working. How to diagnose
Brand:
Model Number: 106.51764510
Main Symptom:
Error Code (if any): No code readout.
Parts or tests already tried:Replaced ice maker assembly and solenoid valves. Water dispenser works right.
With the known issues on this particular style of fridge, I’d take the kick plate off at the bottom and check the wiring harnesses there for any pinched, broken, or damaged wires running into the freezer door before doing anything else.
Okay, thanks. I’ll check that. Is it possible for me to prove that the high ice switch is making and breaking contact. Maybe continuity of two of the six wires coming out of the ice maker?
