Kenmore model 106.7681610 refrigerator/freezer side by side replacing rubber door gaskets
Brand: kenmore
Model Number: 106.7681610
Main Symptom: replacing rubber door gasket
i am replacing the refrigerator and freezer rubber door gaskets that i purchased from you. in this refrig model kenmore model 106.7681610 side by side - very old refrig, there is a metal plate on the doors with screws that goes around the entire doors’ frame of the refrigerator and freezer and most of the current gaskets’ rubber are above the metal plate but it appears that some of the rubber gasket is below the metal plate. your how to video of installing refrig rubber gaskets doesn’t cover this type of situation. would appreciate if a pro can advise me how to proceed with the removal of the old and the installation of the new rubber gaskets in the refrig and freezer doors. also, if tehre are kinks in the new rubber gasket after it is installed can you use a steam gun along the rubber perimeter to remove the kinks. kenmore model 106.7681610 side by side - very old refrig. please email me [email removed]. kenmore model 106.7681610 side by side - very old refrig.
Yes — yours is the older screw-and-metal-retainer style gasket, so the newer videos where the gasket simply pulls out of a groove don’t really apply.
The important thing is don’t completely remove all those screws or the metal retainer. Pull back the inner edge of the old gasket so you can see the screws. Loosen the screws around the entire door several turns—just enough that you can pull the old gasket’s mounting lip out from underneath the metal retainer.
Before installing the new gasket, I recommend soaking it in hot water for about 10–15 minutes. Use hot tap water, not boiling water. This warms the rubber, helps remove some of the folds from packaging, and makes the gasket much more pliable and easier to work underneath the metal retainer.
Once it’s warm, start at the top corners and work the mounting lip of the new gasket underneath the metal retainer. Work your way down both sides and finish along the bottom. Leave all the screws loose until the entire gasket is positioned.
Once everything is in place, close the door and check that the gasket and door are sitting evenly. Make any adjustments you need, then gradually snug the screws around the perimeter. They don’t need to be extremely tight.
If you still have some wrinkles or kinks after installation, you can warm those areas. I prefer a hair dryer on low or medium heat rather than a steam gun because it’s easier to control and there’s less chance of overheating the gasket or the older plastic door liner. Keep the heat moving while gently shaping the gasket with your fingers.
After you’re finished, close the door and check the seal all the way around. You can also close the door on a dollar bill or strip of paper in several spots. You should feel some resistance when pulling it out.
One last tip: don’t completely tighten one corner before the rest of the gasket is positioned. Get the whole gasket installed and lined up first, then tighten the screws evenly. That will help keep the gasket and door liner square.
