Kenmore Elite Electric Double Oven 30” Wide Model# 790.48193002
Brand: Kenmore Elite Double Electric Oven
Model Number: 790.48193002
Main Symptom: Run Away Heating Symptom F10 Error Code
What happens & when: When oven turns on is doesn’t keep correct heating option, overheats without shutting off. Heating element checks out okay within specifications.Code (if an
Photos / video link
There are two things that can cause what you are describing, an oven sensor and the main control. Ohm out the sensor at room temperature, it should read about 1080 ohms. If that is good replace the control.
