I am having a problem with my dryer, I run a drying a cycle and about 10-15 minutes in the dryer faults out with an E1 fault code. Is this thermal sensor replaceable and how would I do that?
You have a bad thermistor located on the blower housing a round small black item. You can click on your model # above to get it.
ok, so I ordered the thermistor and got it today…now how do I replace it? Will I need any special tools…or is there a site I can look up for do it yourself instructions? Thanks in advance for all your help!!!
