Kenmore Elite dryer Door switch and door switch connecter
Brand: Kenmore Elite
Model Number:79681582410
Main Symptom: Door switch and connecter fused and now need to be replaced
What happens & when: I worked on, and successfully, put other parts in. The problem I have now is the dryer door switch and the connector going in to it were fused together and I taking then apart the connector pulled out parts of the door switch and to connector had pieces if it pulled out as well. I know I need a door switch, but I also need a connector going to it. Is a connector available with wiring that I can cut the old one from the wiring harness and splice the new connector with wiring to the wiring harness?
Thank you!
The door switch part number is Door Switch Assembly OEM Part is
EBF61496102 Door Lock Switch Assembly (Washer) | Genuine Lg OEM In Stock and the harness part number is
EAD60843524 Dryer Multi-Wire Harness | Genuine Lg OEM In Stock
Brad,
Is the door lock switch assembly you have shown for the dryer?
Thank you!
