Kenmore electric dryer shuts off
i need help. my kenmore electric dryer (model# 110.66824690)keeps shuting down between 5 and 10 minutes after it is started. I can restart it right away when it shuts down. But then it will shut down again. If I lower the temp to medium/high heat. it will run and finish a cycle.the age of the dryer is about 10 years old not one.
It’s a mystery.
The only I can blame is a poor connection (partially broken wire) somewhere in “the timer - the start relay - the motor” circuit.
