Kenmore Electric Dryer 110.65132411
Based on the information provided, there is a break in one of the wires that supply the timer motor with voltage and/or neutral. There is a black wire spliced into the light blue wire going from the timer to the start switch that would need to be tested for continuity, as well as the white/black wire at terminal T of the timer that would be tested for continuity to the white/blue wire. If one of the wires does not have continuity, that wire has a break and the harness W11197393 would need to be replaced.
