Kenmore Dryer inop--totally
I’ve checked the continuity on every thermostat, temp sensor on the lower end of this unit and they’re all closed. The door switch is good (open circuit when door open, circuit closed when switch depressed. Within the past 6 months I’ve replaced the 2 wire fuse and the 4 wire thermostat with built in heater, drum idler wheels, belt, and given it thorough cleaning. I’ve pulled the panel where the power cord goes in to the back. Each leg is ~118v per leg (+/- 1.5v), but the dryer does not operate: no heat, no tumble, no nothing.
The one area I’ve not troubleshot is the control panel. I don’t know how to go about checking the push to start button, or the timer.
Any help is appreciated.
Let me also add that the heating element ohmed out at 10.2 ohms.
Hello there DeLay,
Did you ever get your dryer fixed?
My Kenmore 80 Series has the same identical symptoms, No power on anything. the tumbler light won’t even go on when I open the door.
But everything I have checked untill now checks out good.
