Kenmore Dishwasher
No water at all coming up…cycles all work etc…no water ?
Hello,
Lift the float switch up in the front corner if you hear a click when you are letting it down then its on track and working fine.
I would suspect that you either have a bad water valve or the incoming water is shut off or has low pressure. We can test the water valve if you like post back and let me know.
ApplianceRepairLesson.com
