Kenmore dishwasher
water fills ok but will not get water up to the top rack the bottom rack cleans fine which part is it usually
the washer fills ok however the top rack rack does not get water only the bottom rack cleans which part is it usually thanks doug
Remove the inlet protector (#8 on the break down diagram) and check the chopper (#6 on the break down diagram).
