Kenmore dishwasher leaks water at bottom of door
Brand: Kenmore
Model Number: 665.13223N414
Main Symptom: Water leak at bottom front door
What happens & when:Was leaking water at bottom of door. Changed the lower door seal & it occasionally still leaks at bottom right corner of door. Should I also change the gasket that goes around the door.
This can be caused by a worn door gasket, overfilling, or a clogged spray arm jet. Does the dishwasher seem like it is filling with water more than an inch above the top of the sump filter plate? Also, does the lower spray arm look like it has any jets that are clogged or any sections that might be cracked?
