The water seems to flow with less pressure and less volume than before. It won’t even go into the soap dispenser. Water pressure in the house is fine and both wall valves are open. Is there an inlet pump that could be malfunctioning? Thanks.
The water flows into the wrong side of the dispenser. It won’t even go into the soap dispenser water only flows into the rinse side of the dispenser. Water pressure in the house is fine and both wall valves are open. Is there an inlet pump that could be malfunctioning? Thanks.
