Brand: Kenmore Model Number: 110.29732800 Main Symptom: Loud grinding noise while agitating What happens & when: When agitating a loud grinding noise is heard.
Already changed dogs (they were gone!) and bolt (all rusty) in agitator. Still doing the grinding sound during agitation. No issue with spin or drain cycles. Can’t get the bottom half of the agitator off to check that but sadly have had several people say it’s the transmission?? Thinking I may have something stuck underneath the agitator as I had to pull several items partially stuck underneath out several months ago (hubby admittedly overfills!) This could have progressed from that incident but it seemed to be working fine. The agitator was turning both ways and needed the dogs. Not sure how long it was doing that. Would love to get that bottom half of the agitator out!
Taking off the lower agitator and checking the splines would be a good choice. If the splines are bad on the agitator base then it could cause the grinding noise. I know getting the base off can be a pain but if you use a 2 x 4 and ratchet straps you may be able to use the leverage to remove it.
