Kenmore 665.13949K013 won't heat water
Brand: Kenmore
Model Number: 665.13949K013
Main Symptom: No Heat
Error Code (if any): 6-6 Cool Water / 7-1 No Heat
Parts or tests already tried: Heating Element replaced which now has a resistance of 38 ohms. Hi-Limit thermostat has continuity (0 ohms), NTC Thermistor aka Turbidity Sensor has a resistance at room temp of 9K ohms. Service info states at room temp the resistance should be 46-52k ohms. I assume that means 46k not just 46 ohms.
Should I replace the thermistor?
Hi, the important reading here is the 9k ohms at room temperature. At room temperature, the NTC thermistor should have a higher resistance than that. As the sensor gets hotter, its resistance should gradually drop.
Since yours is already down around 9k ohms while still at room temperature, the sensor is reporting a resistance that corresponds to a much warmer temperature than the water actually is. This can fool the control board into thinking the water is already hot enough, so it may not send power to the heating element.
To confirm it, disconnect the sensor and measure its resistance while it is at room temperature, then warm the sensor slightly. The resistance should drop smoothly as it warms. If it starts around 9k when it should be considerably higher for your model, the sensor is out of specification and should be replaced.
Hi, here’s how to put the dishwasher into diagnostic mode and clear the stored fault history.
  1. Make sure the dishwasher is in standby — plugged in, but no cycle running.
  2. Pick 3 buttons next to each other, but don’t use Start, Delay, or Cancel. Press them in this order:
1 → 2 → 3 → 1 → 2 → 3 → 1 → 2 → 3
Do this fairly quickly, with no more than about 1 second between each press.
  1. If you entered it correctly, all of the lights on the control panel should illuminate for a few seconds.
  2. If the controls are on top of the door, close the door within about 4 seconds so the diagnostic cycle can begin.
  3. The dishwasher should start running through its automatic diagnostic test, including the drain and wash functions. Let it run for at least 2–3 minutes. Entering diagnostics clears the stored fault history and resets the heater-disable condition.
  4. You can then let the diagnostic cycle finish, or press Cancel/Drain to exit.
After that, run a normal wash cycle and check for heat again. If the heater still isn’t receiving power, then we’ll need to continue testing the thermistor/turbidity sensor, wiring, and control-board heater output.
