Kenmore 11024692300 agitates then stops on normal cycle - runs fine on heavy duty cycle
Brand: Kenmore
Model Number: 110.24692300
Main Symptom: on normal cycle, fills, begins to agitate, stops for 10 minutes
What happens & when: Here is what is happening. I will start the wash on normal, it will fill properly, and it will begin agitating when the water is at the correct level. It will agitate for about 5 seconds then stop. The timer stops ticking/moving and the washer becomes unresponsive. It will not restart if I move it to drain or spin. Maybe 10 minutes later, it will start agitating again for about 5 seconds then stop.
If I move the dial to drain or spin after the washer has been unresponsive for about 10 minutes, it will drain and spin properly and finish out the cycle correctly.
The washer works perfectly on heavy duty cycle.
Based on the description, it sounds like the motor may be tripping on the overload. Check to ensure the motor has power to it, and is it hot.
That’s certainly the case. Yes the motor has power to it and it is hot. What I’m wondering is where to start troubleshooting. Timer connections, motor connections, both?
Troubleshooting is done; replace the motor and capacitor. Make sure all wiring is secure also.
Why would it run fine on heavy duty but not on normal mode if the motor was shot?
When the motor has power to it and it is not running as you stated above the motor is the issue and would need to be replaced.
