Brand:kitchenaid Model Number:kdtm354dss4 Main Symptom:does not run wash cycle What happens & when: When you turn it on the dishwasher fills up and the washer motor kicks on. It then goes straight to drain cycle and drains the dishwasher. No washing. It will complete the rinse only cycle but that is all. Seems to function fine in rinse only cycle and during diagnostic cycle. It originally had the 8-1 8-2 and 6-4 codes in it but after I cleared them they didn’t come back for a day but washer still didn’t work. 6-4 code is back today. I took the sump apart and completely cleaned it out as well as the rest of the dishwasher. The food grinder was full of gunk but the motor still turned. I am wondering if the extra motor load did something to the control board. Owned washer for 7-8 years with no problems. It is in great shape and would like to fix. I am a fairly experienced at appliance repair but this has me baffled. The start resume light blinks like 3 times when it quits.
Error Code (if any):6-4
Parts or tests already tried:cleaned, ran diagnostic cycle many times, checked fuses and some wiring
The 6-4 code is the big clue here. On this KitchenAid, that points to the dishwasher thinking the float/overfill switch is open. Since it fills, circulates during diagnostics, drains normally, and even completes Rinse Only, I would not replace the wash motor or control board yet.
I’d start at the float. Remove the lower toe panel and check the float switch and its wiring. Make sure the float moves freely and actually closes the switch when it is down. With power disconnected, you should have continuity through the float switch with the float down. Also inspect the connector and wiring from that switch back toward the control for a loose connection or broken wire.
The earlier 8-1/8-2 codes are drain-related, so those may have been caused by the debris you found in the sump/grinder area. Since they haven’t returned, I wouldn’t chase those first.
The fact that 6-4 came back is more important. A flaky float switch or connection can make the control think there’s an overfill condition and cause it to abort the wash and go directly into draining, even though there isn’t actually too much water.
I would go in this order:
Check that the float isn’t sticking and nothing is underneath it.
Ohm-test the float switch with the float down; it should show closed/continuity.
Wiggle the switch connector and harness while testing—you may have an intermittent connection.
Check the harness from the float switch back to the control.
If all of that checks good but 6-4 continues returning during normal cycles, then I’d start suspecting the main control board.
The blinking Start/Resume light is likely happening because the control is canceling/aborting the cycle, rather than pointing directly to a bad wash motor.
Given that the wash motor works during Rinse Only and diagnostics, I’d put the control board behind the float circuit/wiring on the suspect list, not ahead of it.
Thanks for the reply Jeffery. I have thoroughly tested the float and wiring for continuity back to the board with emphasis placed on where the wires hinge with the door. I an unable to produce a fault. I have run a jumper across both the float switch and door switch to no effect. I have tested all components and wiring with the exception of the turbidity sensor which seems to have a small board of its own inside. Mine has 8 wires running to it. Everything seems to check out. I have seen many post on the net about people who replaced the control board but didn’t solve their problem. I am guessing that this is because theyreplaced the board without fixing the underlying problems that can stress the board components. Some people make it sound like the boards never fail, this just seems unbelievable to me as I have repaired many boards over the years in appliances, TV’s, powersport equipment, garage door openers etc. How often do you see these control boards fail?
Is it common for them to fail and still run the diagnostic cycle fine? It is a little hard to keep up with the diagnostic cycle as it goes pretty fast. I am pretty sure it is completing the whole thing. It turn the heater on twice which is what the sheet says. The last time in what would be interval 3 at the end of the cycle.
It’s much rarer for them to fail and still pass diagnostics but it is possible. A little bit of scrambled code, a logic fault or a bad component can all do it
