Kbsd618ess01 aqua sense receiver blinking and not making ice
Brand:kitchenaid
Model Number:kbsd618ess01
Main Symptom: ice maker not working
Parts or tests already tried: I replaced the ice maker completely but it still will not make ice. The aquasense receiver is blinking. Should I try to replace the boards there?
This could be a board issue, I am enclosing the tech sheet that has several test to help determine the problem.
TechSheet-W10910733-RevA.pdf (326.0 KB)
Ok, thank you for the sheet! Another question I have is would the ice maker fill and create any ice at all if those sensors are faulty?
Not likely, but I would recommend the tech sheet testing.
