For your Whirlpool ice maker model KUID508HPS01, the fact that the machine appears completely dead, including the drain pump, but comes back to life with a small nudge is a very important clue.
I would suspect an intermittent electrical connection before replacing the main control board. A loose power cord connection, damaged wiring, or failing connection at the control board could explain this behavior.
Here’s what I recommend checking first.
1. Check the outlet and power cord. Plug a lamp into the outlet and gently move the plug to see whether the lamp flickers. If it does, the outlet may have a loose connection. Also check for a tripped GFCI outlet.
2. Inspect the power connections. Unplug the ice maker and remove the lower front access panel. Look for loose connectors, overheated terminals, damaged wiring, or corrosion. Pay particular attention to the incoming power wiring and any connections near the drain pump.
3. Check the control board connections. With power disconnected, inspect and reseat the wiring connectors at the electronic control. A loose connector could cause the entire machine to shut down and restart when moved.
4. Check incoming voltage. If the machine goes dead again, a qualified person can measure voltage at the incoming power connection. You should have approximately 120 VAC between hot and neutral. If voltage remains steady while the machine is dead, the problem is likely farther inside the ice maker.
What about the drain pump?
Since the drain pump also appears to lose power, I would not replace it yet. The pump and ice maker shutting down together suggest a possible common power supply issue. However, we need to determine whether the pump is actually losing electrical power or simply not operating because the ice maker has stopped.
One important question:
When you say a small nudge brings it back to life, what exactly are you nudging?
- The entire ice maker cabinet?
- The power cord or plug?
- The front control panel?
- The lower area near the drain pump?
That detail will help narrow this down considerably. If moving the cabinet restores power, I would concentrate on the power cord, outlet, and incoming wiring connections first.
Safety note: Unplug the machine before moving or inspecting wiring. Avoid repeatedly nudging it to restore power, since a loose electrical connection can overheat.
