KA dishwasher has no power but breaker is working
All of a sudden, the dw will not turn on. The breaker is fine. From your forums, it looks like it could be a fuse or door switch. I will just order both to be sure. Can you give me the correct part numbers or any other advice?
thanks
It can get expensive throwing parts at a problem in hopes that one of them is the cause. If you’re patient and can work with our questions, we can help you narrow down the search and solve your problem in the most economical way.
How do you know the breaker is ok? Did you check for power at the dishwasher?
the dw breaker is with the disposal which is working. I’ve had so much trouble with all my KA appliances that figure it is the problem anyway. thanks
Check the wiring connections under the dishwasher to make sure you have 120VAC at the machine.
yes it does
