Dishwasher works ok but will not drain completly. It leaves abount a 1" of water in the bottom. Drain line is ok. What ya think??
It’s been my experience that if it’s pumping water at all, but not getting it drained all the way it’s because of some kind of restriction.
Thx. I have cleaned the garbage disposal hose out. Where elese would you suggest I look for blockage and how would be the best way to get to it??
can I put draincleaner in the washer and run the drain cycle?? Or should I pull the washer out and and clean out the hose and washer? Can this be done without taking the washer appart?? Thx.
I would not use drain cleaner.
OK Should I pull it out??
