Purchased new burner igniter but unable to remove the screw holding the old igniter. If I drill it out, I need a replacement screw or will a new burner ring come with a new igniter or a screw so I can install the new igniter I purchased?
Try using an ease out tool or you could drill it out and replace the screw,
https://www.appliancepartspros.com/range-cooktop-oven-parts.html
