Brand:Jennair
Model Number:JGRP430WP00
Main Symptom:Gas Oven won’t heat up
What happens & when: Burners & Broiler work properly, oven does not.
Error Code (if any): None detected.
Parts or tests already tried: This unit uses spark ignition. All ignitors spark strongly including the oven. Tested safety gas valve continuity, results are in spec, and voltage to safety valve
