Jenn Air stove, terminal block replacement, do I need to have wire harness as well?
Brand:Jenn Air
**Model Number:**JES9860AAS
Main Symptom:Terminal Block Replacement
What happens & when: The Terminal Block needs to be replaced and I was wondering if I need the wire harness also: PS11742954.
Thank You!
Jeremy Boby
As long as the wiring is not damaged then the harness would not need to be replaced.
