Jenn Air/Maytag Range JGC8536ADS Ignitor will not shut off
Brand: Jenn Air
Model Number: JGC8536ADS
Main Symptom: Ignitor will not shut off
What happens & when: Ignitor sparks, but does not shut off, only on one burner. Right Rear. Unit is dry. All other functions as designed, Burner does light
Parts or tests already trie
Hello, if only one ignitor is sparking, the module is defective. It is designed so that when you turn any burner on, all the igniters are designed to come on and spark. If only one does, the spark module is defective.WP8286828 Spark Module (Reignition) | Genuine Whirlpool OEM In Stock.
All 5 are igniting. Once the right rear burner is lit, the igniter does not stop. It continues to spark
