Brand: Jenn Air
Model Number: JS42NXFXDE01
Main Symptom: lights flick on then dim
What happens & when: door opening, quick lights turn on and dim
Brand: Jenn Air
hi tombslick LED modules may fail for several reasons, including moisture contamination, electrical, temperature, mechanical, andheat cycle stresses. Verify the LEDs are the issue by checking other potential causes, including ● Power going to the lights ● Door switch ● All wire connections at the lights are secured. i have posted below a service bulliten on your appliance
service-pointer-w11606409-revg-BIR LED Lighting.pdf (203.2 KB)
