Jenn-Air JDB6510AWP Cycle gets stuck in middle of ccle
Hi
please help. The dishwasher runs fine after starting and the cycle stops at a particular position. I have to manually advance it just a mm or 2 mm and then it works fine. Generally we use Normal cycle and it gets stuck n between
Running the washer with Extended was-Off, Acu Temp-Off, Heated Dry -OFF
Parts for Jenn-Air JDB6510AWP Dishwasher - AppliancePartsPros.com
Since you have the temperature sensing features turned off it is most likely a dead spot in the timer.
Thanks so much, so do I replace timer? http://www.appliancepartspros.com/whirlpool-timer-99002206-ap4113205.html#qa1
If yes, is there any video how to replace/ or instructions? Appreciated
Sorry I do not have any instructions.
Usually you just remocve the inner panel to get at it.
There is some info on how to release it in the Q&A of the part.
You may be able to find a video on YouTube
