Jenn- Air induction Center plate not working
Brand: Jenn- Air induction
Model Number: JIC4536KS
Main Symptom:
What happens & when: the large Center plate does not work it is not the cookware because the cookware works on the other side 4 plates
The Model # for Jennair cooktop is JIC4536KS
This is likely going to be either the center element W11586463 or the IPC Power Module W11739786. Unfortunately, the manufacturer has given very little testing information on this model so I can’t really point you in a direction for testing to narrow it down further.
https://www.appliancepartspros.com/whirlpool-coil-assy-300-w11586463-ap7186755.html
https://www.appliancepartspros.com/whirlpool-module-w11739786-ap7244908.html
