Jenn Air Fridge JS48PPDUDE01 - Ice/Water Dispenser & Ice Maker Not Working
Brand: Jenn Air - Built In Pro Model
Model Number:JS48PPDUDE01
Main Symptom: Dispenser Control Not working, no water or ice dispensing and Ice maker not producing ice. Everything else in the refrigerator is working.
What happens & when: We did have a power outage the evening before problem was noticed (the unit was hooked up to generator w not problems until power was restored)
Parts or tests already tried: Tried resetting circuit breaker, turning on and off , checked locks and main control panel settings.
If everything else in the fridge is working, I would suspect the dispenser board AP6007328.
The ice and water switches are connected to it, as well as the keypad, and it has the display build on it.
https://www.appliancepartspros.com/whirlpool-cover-assy-ui-wp2321746-ap6007328.html
