JEN AIR COMBO Oven/microwave displace Model Jwm2430LL00 said E2F1
Brand:Jen Air
Model Number: JMW2430LL00
Main Symptom: Electric Control Panels
What happens & when: right now
Error Code (if any): E2F1
Hi, the F1E2 (or E2-F1) code on your JennAir JMW2430LL indicates a communication problem between the user interface and the control system.
I would start with a hard reset. Turn the dedicated breaker off for about 10–15 minutes, then restore power and see if the code returns.
If it comes back, turn the breaker off again and check:
  1. Make sure all wiring harness connections are fully seated.
  2. Inspect the ribbon cable and connectors for corrosion or damaged contacts.
  3. Look for pinched, broken, or overheated wires.
  4. Check the control boards for burn marks, discoloration, or damaged components.
For the final diagnosis: if the wiring and connections check out good and the F1E2 code continues to return, that points to an internal failure of the user interface/control assembly rather than a wiring issue. At that point, the affected UI/control assembly would need to be replaced.
Run Through the test, clean up all the moisture, your though of w11448962
