Brand:Samsung
Model Number:DW80R7061UG
Main Symptom:Leak
What happens & when: it leaks when I’m not watching it.
Error Code (if any): I forgot L1 possibly
Parts or tests already tried:cleaned the sump screen
Brand:Samsung
Main Symptom:Leak
When the base is inspected, are there any water streaks or residue that are leading from a specific location?
I couldn’t see anything from the side or back. Next time it happens I’ll turn it on it’s side and remove the base pan. It’s been fine for a week now so I’m expecting it to happen soon.
It leaked again. There are 2 hoses connected to a box on the side about half way up, then connected to the inside with an o ring. I took it off, it looked pretty bad. Sanded the rust off the washer surface, cleaned the o ring. It’s been 3 weeks and no leaks.
Let us know if anything comes up again.
