Is there another replacement for this discontinued item
Hi
I have a Jenn Air CVG 2420B and can replace it with a CVGX2423B. The problem is that I have had several problems with the fan switch on my current model and am worried to replace it with another stove with the same faulty part.
Is there a replacement for this part # [COLOR=#0000ff]AP367072[/COLOR] that would work with the Jennair CVGX2423B? What does the grommet, that is available, do, ie part #[COLOR=#0000ff]AP4292546[/COLOR] ?
Thanks so much
Here are the parts for a GVGX2423B
Top assembly replacement parts for JENN-AIR CVGX2423B | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/maytag_library/docs/16010492.pdf
Here are a couple tech bulletins on the fan switch
http://www.servicematters.com/maytag_library/docs/TDC-0021A-B.pdf
http://www.servicematters.com/maytag_library/docs/TDC-0102-B.pdf
If I cross reference to this site 74009245 comes up as
AP6011114
12002045 comes up with the above but also with another part. You would have to check with the parts people at AppliancePartsPros to clarify the difference.
As far as I can see the grommet fits into the hole for the switch so that there is some give, so the glass does not crack with expansion/contraction.
